I'd be choosing the LS3 if it was my car - more potential with the greater displacement.
Ok guy I search on here trying to find out how a L98 compares to a LS3 both in standard form but came up with nothing, I am sure there has to be something in here somewhere.
Well what I am trying to find out is how a L98 stacks up to the LS3 engine as I am debating which way to go for an engine transplant into my VY.
If both motors were unopened and in standard form except got a 92mm FAST T/B and 4 into 1 Pacemakers and a duel 2.5” exhaust.
I would like to think spending the extra $2000 approx for the LS1 is justified or if I was to put the $2000 into the L98 (Cam wise) would be the better option.
Hopefully I can get a few answers here.
Cheers.
Some say the glass is half full, some say the glass is half empty. I say "Are you gonna drink that?"
HSV Senator 300 - the Classy C4B..
C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
308rwkW(413rwhp)
http://www.cardomain.com/ride/389253...lden-commodore
In stock form the LS3 has a more aggressive camshaft and higher compression ratio, larger displacement too. Get an LS3, they are going for around $7K and an L98 is around $5K, better money spent on an LS3 i think.
LS3 cam only, a potential 350 rwkw
LS3 is around 160cc more capacity, slightly higher compression due to larger capacity, and in stock form has a better cam than L98. The heads and intake flow the same, though the intake valve in an LS3 is hollow stem and slightly lighter for an upgraded rev limit.
If you are changing cam, then from the LS3 you gain a couple percent more displacement, and slightly higher compression plus bragging rights that you have an LS3 up front!
i was also thinking about a ls3 for my vy calais. but i think id rather a ls7.
were in Brisbane can i get a ls7? how much would it cost?(i herd there worth 20k) would it even fit in the bay? how much would i get for the ls1 that comes out(good nick only 50k on it)
LS3 tune only with orssome intake = 12.99 1/4 mile
If you can afford an LS3 get it
but would a ls7 fit in a vy bay?
go the ls3 mate from sams thats what ive been looking at for a while, but im just trying to find the right car to put it in.
That sounds like a great deal. Heard they had one that had a piston failure. Maybe that's it.
Same external dimensions as LS1, LS2, L76, L98. LS3. LS7 is a Gen IV SBC, and looks almost identical externally to these other GenIII/GenIV engines.
One area to work through is that it comes with a rear sump dry sump setup. Either spend a few $k fitting the engine bay out for the dry sump which wont clear the k member and needs a reasonably major rework or convert it to wet sump.
ls3 is a great engine,great hardware
But some of the claims of 350,360,370 rwkw out of these ls3 that i have been hearing about from some people are starting to get a bit old.........................
maybe in time to come.................
