Should just be good to go but it's always good to have a balance if you haven't had one for a while. The place I get my tyres from give me a free rotate and balance every 6 months
It's almost that time to swap the tyres on the Senator (side to side because of the staggered rim widths). Does that type of thing require a balance afterwards or should it just be good to go ?
Just remember you cant flip assymetric tyres on the rims. ie swap the fronts across. They are directional and specify the oputside edge of the tyre. If some misinformed tyre fitter says you can then be very wary. Mounting assymetrical tyres backwards is a big no no. Will also void your insurance if you are involved in a bingle.
I was assuming korrupt was planning on taking tyres off the rims for this? If so, I would have thought a balance is also required.
There wouldn't be many non-directional tyres out there these days would there?
Ok this just did my head in - maybe someone can point us to "Tyre Rotation for Dummies" somewhere
Last edited by V28VX37; 11-07-2011 at 07:27 PM. Reason: Saw new reply after posting
If your suspension is set up ok I am not sure what you will gain by doing this. FL probably cops more of a hammering with roundabouts than the FR but the rears do the same work. Both my E series wear the tyres flat across the tread so swapping them side for side won't do anything. In fact the tread wear is so even it's scary. Very happy to be corrected of course.
Cant do it. Direction of rotation will be reversed if you swap the rims around. I have looked into this in an effort to get more than the 32,000kms I got out of my first set of tyres on my VE GTS. Kills me, on the VX I got 55,000kms out of my last 2 sets of tyres and was informed I had done really well. Apparently 25,000kms is average on VE HSV's
At the end of the day tyres, brakes and petrol are the cheapest part of the car. Just buy new tyres and enjoy the drive.
OK FOR THE DUMMIES
DIRECTIONAL - this tyre will have a arrow pointing in a forward direction on the outside of the tyre. This tyre can be rotated from side to side provided the tyre is removed from the rim.
ASSYMETRICAL - this tyre has a inside edge and a outside edge (designed to be a quieter ride primarily) these tyres can be home rotated.
Balancing is always a good idea if the wheels are off, hence why most go to tyre shops.
For the original op unless you can see a difference from side to side you should just leave them. If one side is wearing more make sure you get a good 4 wheel aligment with your next set of tyres.
NB - there is a theory that a tyre develops a "memory" of its direction of rotation. When turned the opposite way balance issues can arise, higher potential noise - due to possible suspension issues. going by this theory assymetrical tyres should stay on the same side of the car.
why would you even bother, the amount of money spent rotating & aligning wheels doesnt make up for the savings in wear, not to mention the increase in road noise & vibration
If korrupt is going to do it himself at home, then there's no monetary spend, only time taken. BUT, since TIR33D is the expert here, I'll happily take his recommendation.
Oh, and just to clarify what I wrote earlier, my tyre guy that rotates and balances my tyres for free every 6 months does so on my non-staggered Subaru Legacy (Liberty for you guys). I've never rotated my Maloo tyres
