Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Thread: VZ Body Control Module
  1. #31
    IJ.'s Avatar
    IJ. is offline One of the Top Contributors to the Forum Last Online: 02-08-2018 @ 01:19 PM
    Mar 2009
    The Bush
    7,760
    Re: VZ Body Control Module
    I'd just go the high pressure spring right off then adjust Hot Idle pressures with Oil viscosity if needed..
  2. #32
    Quote Originally Posted by mcsquirt View Post
    Which Melling Pump are you going to use? M295 / 10295 / 10296?
    Have you decided which spring setup you are going to use (Standard Pressure / High Pressure)?
    If you are putting in a double row timing chain the Oil Pump clearances can be a problem and a Melling pump may not be the right choice.
    Standard single Row Chain should be easy fit - there are some great guides on fitting the pumps on youtube.
    Would be very interested to see what Oil Pressures you get after the pump is changed out.
    Really a no brainer to go the heavier (higher press) spring as they do wear out & a bit of work to strip off balancer/cover to do again. Went for a single kit with new cogs to suit.
  3. #33
    mcsquirt is offline Rarely Contributes to the Forum Last Online: 14-04-2024 @ 08:54 AM
    Nov 2005
    83
    Finally sorted out the ticking lifters - new Melling 10296 oil pump with the standard pressure spring - also fitted a Setrab 625 oil cooler and a 185 Deg F Thermostat for the oil cooler - all the parts came from improvedracing.com in the USA. The temperature is rock solid at two needle widths above 1/4 on temp gauge. The oil pressure is never less than 200 kpa even when towing, on a 40+ degree day and when stuck in bumper to bumper holiday traffic. Woo Hoo! Been in now for about 2 years very solid and stable performance mod!
