Everything here barring the RideOn Mower and the GF's Corolla are AWD
Or the Corolla should be very scared. There would probably be enough parts lying around to shoehorn a diff in the back n a supercharger/turbo up the front.
Today!
Had to go put the Bin out and while I was in the shed I thought I'd have a go at removing the Pass side Cross member mounting...
Wasn't as neat as I'd have liked but I have to pull the seat and carpet on that side so I can weld the new mount in place so I'll tidy it up then!
Today!
Went out rugged up with 3 layers of clothes on, played Musical Engines and Transmissions to clear enough space to roll the Adventra out then pulled the Cable Shifter out that I need for the conversion, also removed the "BracketOdoom" that converts the 2wd floor to AWD
Got the Monaro back on the Floor so I can pull the pass side interior and weld the new Bracket in place once I've made the Captive nuts for the AWD Tq Crossmember.. At this stage it's a bit of a Rubik's Cube and needs to happen in an exact order, once the mounts are all sorted I'll Swap the Sumps/pickups so I can bolt the Front Diff on and reinstall the Engine/Trans.
Sounds like good progress is being made...
Past the point of no return now
Took me awhile to fully commit wanted to make 100% sure it was going to work and give a good result.
Only been a few small "got ya's" but nothing insurmountable, I could easily have fabricated the missing mount but wanted to make this look as "Factory" as I can, also upgrading a few things to VZ spec while I'm at it and have a full set of Avalanche Brakes coming to replace the dogshit Stock Brakes.
LOL Mick I'm just a talented hack
IJ'S AWD Conversions - making a great car better
Made me
Today!
Taken me 2.5 hours to actually get to the floor so I can patch up where I drilled the spot welds out, Glad I did it this way as the amount of Deadener under there once burning would have been impossible to put out....
I'll head down after lunch and weld up the holes then make a start on the captive nuts to hold the Tq Member on.
