Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Thread: 6.0lt RX8
    rx86.0lt is offline Has Not Contributed to the Forum Last Online: 12-09-2014 @ 09:57 AM
    Nov 2013
    Queensland
    6.0lt RX8
    Hello forum members
    I have recently embarked on a new project and i thought some members on here may like or be interested in what i am doing.
    9 years ago i bought a Mazda RX8 brand new.
    Its been through some family members hands and came back to me approx 2 years ago with a dead motor. I rebuilt the original motor into a BridgePort 13b Renesis. Spent thousands more on other modifications turning it into a weekend track toy, though still keeping it street registered.
    After 2 years, i had enough of the slow 13b, pulled it out and sold it recently. I then decided to buy a VE SS Thunder 6.0lt Manual ute that had been in an accident.
    Pulled engine box and everything else i need for the conversion. (I can not post pics of ute up but its been in a front end hit). Also bought DOD delete kit, cam, dual valve spring kit with seals retainers and bases, under drive kit inc belts and replacement drive pulleys, 3 bolt cam gear, crank seal, pushrods. Should make abit over 300rwkw.
    In the end it will be my weekend toy, that i will do hill climbs, sprints, track days and what ever else i can and have fun in.
    I will update as i go.
    h.
    Drizt's Avatar
    Drizt is offline Forum Contributor Last Online: 31-03-2019 @ 11:07 PM
    Mar 2002
    MELB
    1,482
    Re: 6.0lt RX8
    AWESOME
    Will it all be engineered and street legal when done or just a track car?
    VE Calais V tuned by APS
    BigAnt is offline Forum Contributor Last Online: 18-03-2018 @ 06:34 PM
    Aug 2004
    South Aus.
    39
    557
    Re: 6.0lt RX8
    Looks like a fun project. Great to see another build going up on the forum too.
    Haven't seen a LS RX8 in Aus before. Id love and LS FD but I'd never fit in one.
    Are there conversion kits available from the USA or are you doing it all here?
    Keep us posted
    Evman's Avatar
    Evman is offline One of the Top Contributors to the Forum Last Online: 11-12-2016 @ 11:07 AM
    May 2006
    38
    6,622
    Re: 6.0lt RX8
    Huuuuuuuge fan of LS FD RX7's. This conversion would rate. Keep us posted!
    Nov 2013
    Queensland
    Re: 6.0lt RX8
    I plan to get it engineered. I would like to keep it st registered as i want to drive to and from events.
    No conversion kit. I tried sourcing information from the states but they were not very helpful. the 2 main issues will be the headers and sump. Everything else shouldnt be too much of a drama. Dale from CHE is helping with the conversion. He will be modifying the harness etc so we can get the 6.0lt running with the factory ecu and fbw.
    Woodchukka is offline Fair Contributor to the Forums Last Online: 29-05-2019 @ 02:24 PM
    May 2011
    Hunter Valley
    1,877
    Re: 6.0lt RX8
    Sounds like it will be a great little car. Look forward to seeing this develop.
    itsme4g63 is offline Forum Contributor Last Online: 18-09-2014 @ 01:02 AM
    Aug 2012
    Chicago, IL
    327
    Re: 6.0lt RX8
    niccceee! thats the way I'd go if I had one of these, that or a 2jz swap. More pics please!
    zorro's Avatar
    zorro is offline Substantial Contributor to the Forum Last Online: 25-04-2024 @ 07:44 PM
    Jun 2006
    SE Melb
    4,930
    Re: 6.0lt RX8
    I hear CarGraphic do good headers
    Good to see you here H, this is going to be a fkn cool car when finished
    GM: Has millions of dollars and highly trained engineers.
    Guy in his backyard:
    Has a hole saw.
    brasher is offline Forum Contributor Last Online: 26-04-2015 @ 10:54 AM
    Jan 2007
    449
    Re: 6.0lt RX8
    If it's one thing H doesn't do.... it's f^&k around lol
    this thing is going to be mental.
    vassis is offline Forum Contributor Last Online: 02-03-2014 @ 01:25 PM
    May 2009
    Caboolture, QLD
    326
    Re: 6.0lt RX8
    Ive worked on a FC with a stock ls1 (small cam)+ M6, a FD with a L98 (small cam)+6l80e and a HQ with a bog stock ls1 + M6
    I love conversions. Its amazing seeing how these engines go in cars that dont weigh as much as commodores do. You will like the end result. The idea is to keep near stock and reliable setups yet run great times its just reliable reliable reliable hence why the small cams. Even a entry level blower on a stock motor with a decently setup car will get your mazda running in the 10s
    The FC on a safe street tune ran a 12.29 @115mph with a 60ft time of 1.75 using an old set of street ET's and manifold going under vacuum at WOT and injectors maxxing out @ 4400 RPM @58 psi, so its got so much more in it if he wants to spend money on it but its already running low 12s with a engine no different to most of the entry level modders on this forum
    Ill be following this and if you get stuck on anything PM me
    ittwgn is offline Forum Contributor Last Online: 04-06-2018 @ 07:41 PM
    Oct 2007
    runnin 8s@wsid
    1,126
    Re: 6.0lt RX8
    sounds like a cool project!!! a mate at work just did the usual rebuild on the rotor less than 100k from new !! hinson are one of the few I've seen working on this type of conversion they build some insane cars !!! probably one you had no response from !!??
    http://www.hinsonsupercars.com/s-115...-rx8-2003.aspx
    Nov 2013
    Queensland
    Re: 6.0lt RX8
    Yep Hinson do but doesn't really help rhd cars.
    Vassis, what did you do in regards to return line? The rx8 doesn't run a return line. What fuel pump and reg did you use?
    Thanks
    H
    jc_sv8's Avatar
    jc_sv8 is offline Fair Contributor to the Forums Last Online: 22-04-2024 @ 01:46 AM
    Mar 2004
    1,708
    Re: 6.0lt RX8
    Looking forward to the build. One of the guys here has an MX5 with a LS2 in it. Scares the bejesus out of the Porsche's at Barbagallo.
    May 2009
    Caboolture, QLD
    326
    Re: 6.0lt RX8
    Anything good fuel system wise. All fuel systems use a return from the regulator just the commodores have them near the back or somefin. Use intank walbros feeding a 044 outside if you need that much or just an oem intank replacement. There's a few really high flowing ones out now upto 400 lph
    VNV8 is offline Fair Contributor to the Forums Last Online: 06-01-2020 @ 03:24 PM
    Sep 2005
    brisbane
    1,786
    Re: 6.0lt RX8
    Sounds promising, what sort of bodywork are you going to have to do? E.g. chassis rails, trans tunnel etc.?
  1. 5.0lt tune
    By Maccas in forum General Automotive
    Last Post: 06-01-2009, 07:40 PM
  2. FS: 2003 Mazda RX8
    By AndyP in forum Vehicle Classifieds/Wanted to Buy
    Last Post: 30-11-2006, 05:42 PM
