Page 1 of 23 1 2 3 4 5 11 ... LastLast
Results 1 to 15 of 342
Thread: VE SS-V GEN4 Engine OIL- Which is best?!
    jonnyd1986 is offline Occasional Contributor to the Forums Last Online: 21-12-2014 @ 10:51 PM
    Dec 2007
    38
    287
    Hey all what engine oil is best for these engines? Which oils protect the best and dont burn...etc
    I've been putting Penrite's SIN engine oil in my VE SS-V every 11000kms odd. I've got a service coming up so i just wanted to know whats the best oil i can get.
    Also whats the best oil i can put in my stock diff? Cars done 32000kms.
    Thanks.
    Jon
    macca33's Avatar
    macca33 is offline Powertrain Control Last Online: 07-09-2021 @ 06:43 PM
    Sep 2005
    The 'gul
    52
    8,303
    Re: VE SS-V GEN4 Engine OIL- Which is best?!
    There are plenty of oil threads to assist you - do a search and all will be revealed. Also, check Mainlube's sponsor section for some very good tech info.
    Many have different brand loyalties, etc, so read up and make a decision for yourself.
    For my donk, Castrol Edge 10w60 with new filter every 5000ks.
    Cheers,
    Macca
    HSV Senator 300 - the Classy C4B..
    C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
    308rwkW(413rwhp)
    http://www.cardomain.com/ride/389253...lden-commodore
    VZ_V8's Avatar
    VZ_V8 is offline Fair Contributor to the Forums Last Online: 20-05-2021 @ 06:25 PM
    Jun 2007
    34
    2,757
    Quote Originally Posted by jonnyd1986 View Post
    are the newer models only recommended to have oil changes at intervals that far apart. I do mine every 5K max, bit of insurance for next to nothing considering i do it myself. BTW i use Motul however mine is a 6. Dad uses magnatec in his LS1 after good reviews from people using it on here, quieter than when it was on mobil 1 or penrite.... anyways there are lots of oil threads around which arent reall that old...
    Dec 2007
    38
    287
    Quote Originally Posted by macca33 View Post
    Macca
    Thanks although I did search before posting the thread but didnt find many/any talking about engine oils. Especially VE V8's.
    Jon
    VZ_V8's Avatar
    Jun 2007
    34
    2,757
    although i'm not 100% sure, I would say that the engine oils which are best for the VZ 6l or even the 5.7L would be good as well for the VE 6l, same engine materials and setup.
    Ridin-High is offline Forum Contributor Last Online: 12-09-2011 @ 01:33 AM
    Feb 2007
    37
    575
    Royal purple k thnx bye
    SS Enforcer's Avatar
    SS Enforcer is offline Substantial Contributor to the Forum Last Online: 17-07-2011 @ 10:11 PM
    Jul 2003
    Sydney's West
    62
    5,449
    The last 2 changes have been Mobil One on recomendation from my mechanic no complaints from me so far. I change it every 7-8000 k's.
    hithere's Avatar
    hithere is offline Occasional Contributor to the Forums Last Online: 29-06-2014 @ 12:32 AM
    Jul 2002
    246
    OP, how many kms on the clock?
    I am under the impression that rings have to bed in while the engine is new. So, for the first 8,000 - 10,000kms, I am using 100% mineral oil to assist this process. Friction modified/synthetic oil prevents this from happening properly.
    After 10,000kms, I will switch to something of a blend.
    Also, my understanding of oil is that if you stick with big brand names, any oil will do as long as you replace them more frequently than 15,000kms. I plan to change oil + filter every 7,500kms.
    Space Pope's Avatar
    Space Pope is offline Forum Contributor Last Online: 25-09-2019 @ 11:00 PM
    Jan 2002
    Central Coast NSW
    60
    794
    Yeah any good quality oil is fine...10w30 is ok but I prefer a 10w40 in these motors. I've slated the change intervals for this car at 7,500 km rather than 5,000. I think with the oils these days that's a fair thing as long as you use an engine flush with each service.
    My motor might have used 100ml in 7,500 km which isn't bad...especially compared to the early LS1's (and that is using dealer 10w30). So I can't see you'll need to top up between sevices with normal use. Just check the oil every week along with your other checks.
    Cheers....Space Pope.
    "Done with the car mod rorts ...gimmie a reliable stocker and I'm happy"
    AndrewMSS's Avatar
    AndrewMSS is offline Forum Contributor Last Online: 05-04-2019 @ 07:49 PM
    May 2008
    Carrum, Melbourne
    373
    Quote Originally Posted by Ridin-High View Post
    Yep, Royal Purple 10w40....expensive but you will notice the difference.
    HEXEM is offline Forum Contributor Last Online: 17-08-2013 @ 04:35 PM
    Mar 2008
    hmm
    709
    Hi all,
    Well I did some ringing around different holden dealerships today asking what brand name engine oil, viscosity, blended, fully synthetic they use.
    The most common response from the 20 dealerships I called (in NSW) was that they used the following: Mobil Super S 10w-30 (Blended oil) and Mobil 1 10w-30, 5w-30 and 0w-40, also Valvoline Problend 10w-30 (blended oil) a 10w-40 (blended oil) and Valvoline SynPower 5w-40 (synthetic).
    A couple of dealerships used the Castrol Magnatec 10w-30 (blended oil) and a10w-40 (blended oil).
    1 dealer service department uses Caltex 10w-30 but was unable to tell me the series name Caltex oil used.
    The holden dealer that uses the Mobil 1 0w-40 said that they are using it on all the Gen4 (LS2) engines in the VE range and have not had any issues. The dealer is also a Mercedes Benz (sorry about the spelling if I am wrong) dealer and the Mobil 1 0w-40 oil is the only one recommended for that vehicle.
    My question to the group is, is there anyone using this oil currently in their VEs, what is it like?. As I am in Canberra we have low temps overnight and the first start up is where you want the oil up top as quickly as it can (so I am told)
    I am thinking of putting this oil in my VE SSV. I can buy it direct from a Mobil outlet here for $64 per 5ltr container, cheaper than the 10w-30 mobil 1 from supercheap (around the $85 mark).
    The workshop mechanic I spoke to at the dealership said that the 0w rating allowed the oil to get to the top of the engine alot quicker at colder temps etc etc.
    I know this topic has been prolly flogged to death but are there any thoughts out there?.
    Phil
    igniton is offline Occasional Contributor to the Forums Last Online: 15-11-2009 @ 10:39 AM
    Jan 2007
    nsw VE SS A6 Auto with
    277
    i use caltex havoline 10w/50 synthetic in my cammed VE SS
    very smooth and quiet cold start ups.....
    i did use mobile 1 10w/30 for a while but my valve train was a little bit noisier with my camshaft lobe profiles....
    all good now with the 10w/50 in...
    Mar 2008
    hmm
    709
    Hi all,
    Well I went out and bought Mobil1 0w40 today and it will be put in the car in the morning.
    I spoke with more dealers around the country today and found out that holden released a bulliten on the use of Mobil1 oil for HSV and 6.0ltr V8 range.
    The traditional Mobil1 10w30 have been superceeded with Mobil1 5w30 or 0w40 with a whole lot of other info he read out.
    Some of the dealers I spoke with today said they are using the Mobil1 0w40 for the HSV range and some customers (who can afford it) are using it in their V8 range commodores. When I mentioned I lived in Canberra where this morning it was -4 they said that the 0w40 would be ideal but admit that if you lived in the north of Australia where the temp is alot warmer you might not need the 0w rated oil.
    The dealers I spoke to also sell Audi and Merceedes and said that the new rated Mobil 1 0w40 oil is standard fitment for these euro cars and warrenty could be voided if not used. There is also a variant to this oil and its the ESP version (specific to euro cars). This version is only available in workshop quantity. When I spoke to the mobil oil outlet here in Canberra the guys that delivers it said only 1 dealer in Canberra uses it, the rest get the new super syn Mobil1 0w40 which you can buy off the shelf in 5ltr containers ($64 each).
    Anyway I thought some of you might like to know this info (some might not care... lol). I will let you all know how it goes and what I think of it..
    Cheers for now
    Phil
    CSP is offline Fair Contributor to the Forums Last Online: 16-02-2010 @ 10:43 PM
    Nov 2007
    Canberra
    44
    2,977
    I'm 1000km away from changing my oil. Will have to give the new Mobil1 0w40 a go I think.
    Wonky's Avatar
    Wonky is offline One of the Top Contributors to the Forum Last Online: 19-04-2024 @ 12:49 AM
    Officer
    15,164
    I asked a well respected tuner/sponsor after being told he recommended a particular product and found out it was CASTROL EDGE SPORT. Will have to check the container tomorrow to see what viscosity as can't remember for sure. Put it in 1,000km ago at the 15,000 service and no complaints so far (not that I drive my car hard enough to tell).
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. Oil Filter Location in VE 6.0L Engine
    By MK1 in forum General Automotive
    Last Post: 29-02-2008, 07:54 AM
